Yea...that’s what it came out to be. Wasn’t expecting that.Wait...392ft/lbs of torque?
I’d love to do a new dyno after each part, but I have to drop the car off each time and pay for the pulls. So I think I just want to do all the work and then do another dyno. Eventually I’ll do more work after that and of course more dyno pulls.You going to do a new dyno after each bolt on or after putting all 3 mods on at once. It would be interesting to see what each mod does seperately but I know it would be a PITA. Can't wait to see the final numbers. That torque number stock is wow, were these severely understated by factory?
I agree, depends on what type of dyno, altitude, temperature, etc...Well take the numbers with a grain of salt. 5 dynos will give you 5 different readings, so they're not perfect for figuring out the actual power the car is putting down. What they're perfect for is getting a base reading then re-measuring after changes are made to see what the power difference in the before/after is, which should be perfect for Bear's use. Even the 329 whp would only be a 10% drivetrain loss in power which seems a little optimistic.
Yes, it is AWD GT2.Is it AWD? I didn't see the op confirm
When I get home, I’ll check the sheet.His dyno sheet says AWD.
@Bear can you show the graph with the RPMs up top visible? Or confirm my guess...the first line is 1500 rpm and each subsequent line is +500?
