Rufus
1000 Posts Club!
My preference is called Unobtainium...it lasts for 5 years and never needs reapplying. It's also bulletproof. The only problem is you can only purchase it with the $85 dealer upgrade that boosts the 3.3 by 100hp
I got to test the hydrophobicity property of the Fusso right after I waxed it, rained right after! So I am happy to report, the Fusso sheets water very well indeed.Like most sealants, Fusso doesn't give the craziest deep watery lush a carnauba wax gives on darker colors. But Fusso 12M is one (not the only) of the longest lasting "simple" (as compared to cermic coats) to apply and remove protective layers. It should outlast a carnauba wax by at least double the time and it has an insane hydrophobicity. I like it because I'm lazy.
Other stuff you can loot at: Bilt Hamber Double Speed Wax for easy on and off and a good lasting sealant as well or if you want longest lasting things, a coating like CQuartz UK, which just came out in a "3.0" version, claiming to be all betetr than before (and which is Korean, too .. Car Pro). but those are semi permanent and require a bit more care and focus, when applied, plus more expensive. but they can last 2 years+.
Your car looks fine ... make sure you don't have "clouds" ... fusso, when applied too much, can leave a cloudy effect in some places. Also: Have you let abit of water go across your hoodThe effect is stunning.
I think you are right. I may still try a panel or so first, want to see if the carnauba would be out more gloss.That won't work well. The wax won't stick properly to the Teflon fusso. Also you'd lose its hydrophibicity ... it makes no sense, stick with the Fusso![]()
Would take a long time to answer all those questions... my suggest would be, go look at ceramic coating for your car.I want to leave the Zaino (long term Vette Forum favorite) products behind and move to a product line that I can deal with paint protection on 5 vehicles ranging from 1987 truck to 2018 Stinger. I care less about ultimate shine and more about durability / protection. I did check back on the Vette Forum; as many recommended products as posts: Meg, Zaino, Chem G, even Nu Finish. Some good points made:
End result only as good as prep: wash, clay, polish....
Difficult to tell real difference as far as initial looks between two good waxes / sealants if prep good / same.
Color correction is really clear coat correction, how much clear can u correct for how long and how do u know this must be done?
I went to the Chem Guys site and was overwhelmed. So questions:
Can everything be applied well by hand or is a DA polish machine a must?
With so many different vehicles, assume I have to buy different prep and wax / sealants?
Assume most products have a shelf life?
Is there good independent lab evals (optic qual, hydro / beading, durability, affect on finish with long term use, daily driver subjective reviews....) of some of the products listed here?
Thanks..
Some good points made: End result only as good as prep: wash, clay, polish....
Don't like them myself with the exception of very few products. Too many products that fail in vids I saw. There's tons of better and way cheaper brands.I went to the Chem Guys site and was overwhelmed.
Thanks..
