BIG-D
Curious about your throttle body please ?
I just bought the AFE intake pipe and I want to buy the BIGGER TB as well
Thank you, but where is it returning from? I couldn't see where the side opposite the big coolant pipe connects, is it in the block valley or heads?The blue line in the second picture is the “coolant return” or the low pressure “hot side” of the coolant system.
Thank you! So no additional under-manifold circuit that would be worth bypassing then, besides the TB...It joins to the T section above the Waterpump where we burp air out of the coolant system...
Not being a knocker at all, but you are relocating a sensor and great job by the way.The blue line in the second picture is the “coolant return” or the low pressure “hot side” of the coolant system.
In the genesis coupes we do the coolant bypass aswell. We did not cap off the lines but connected the feed and return directly. The hose on those cars was long enough to loop directly. In these cars idk. I also don’t think it’s necessary anymore because “IAT sensor relocation kit” solves the manifold heat soak issues.
Iv seen very good gains on my genesis coupe anyway. But that thing is modded to hell and back.
It wont do any harm. Iv had my genesis coupe for 9 years now and at least 6 of those years iv had the coolant bypass "installed" and haven't had any issues. It definitely does create a source of heat which heated up my aluminum intake manifold and definitely robbed me of power compared to when I relocated my tmap sensor to the intercooler cold side piping.Not being a knocker at all, but you are relocating a sensor and great job by the way.
We are stopping 103 degree coolant flowing thru the throttle body for no apparent reason, well in my climate anyway...
Daz
It's common on other cars. The stated reason is to keep the throttle from potentially freezing/sticking in very cold weather, which always seemed very unlikely to me given that the engine bay and block are 100+ degrees even in the coldest conditions.I've never heard of coolant going to a throttle body.
Obviously the designers must have had a reason for that.
Seems they want it at engine temp for some reason?
anybody know the actual reason?
