7thSonEngineering
- Oct 26, 2024
Car: Kia Stinger Gt AWD 2019
Ambient temp: 33f
Weather: Snowing
Date: 12/21/2024
Time: 4:16am - 4:38am
Purpose: Testing potential mod
Mod Name: IAT sensor relocation kit (prototype)
For sale name: Kia stinger Gt Real IAT ( Jan 2025 release ebay)
Car Mods: BMS BEF, Takeda intakes, Megan secondary downpipes
The purpose of this post is to investigate whether relocating the Tmap (temperature + mass air pressure) sensor increases the Hp and torque on a kia stinger or any other vehicle with this motor ( 3.3t). Why would someone want to relocate the Tmap sensor you ask? Because the Tmap sensor is attached to the intake manifold which heat soaks and this effects the minimum IAT the the engine will see. This effects timing, HP, TQ and Mpg. Typically the IAT sits between 20-40f above ambient.
The relocated location of the tmap sensor is actually the stock location for the map sensor on this motor. The Tmap sensor is located behind the throttle body (figure 1) and the map sensor is located on the charge pipe before the throttle body (figure 2)
(figure 1)
(Figure 2)
So the Map sensor and Tmap sensors swap places. This makes this Mod completable in 5 minutes with my sensor relocation cable.
Lets get onto the prototype installation pictures.
Now beings the road test. Notice the Time in the top left hand corner of the screen shots.
Time: 4:16am - The temperature ambient temperature was 33f this screen shot is post pull (50mph -120mph). Notice that my lowest IAT (intake Air Temperature) temps were 39.2f. The peak IAT Temps were 48.2f. (Hp and torque numbers are estimated by the app)
Time 4:21am - I Pulled over on the side of the highway and removed the mod. Reset the app values and this is what the IAT temp shot to 60.8f. So now that I'm back to stock I will do another pull (next pic)
Time 4:22am- Notice the peak HP and Torque numbers (estimated) and compare them to the picture at 4:16am. (54-130mph pull). Also note that with the sensor relocation mod the boost levels are lower (idk why)
Time 4:31am - I pulled back over and reinstalled the mod got back on the highway and did a pull 111mph top speed (remember it was snowing).
Time 4:32am- Just cruising along and letting temps drop to see where they fall back down to.
Time 4:38am- Driving on the highway and checking to see if my mpg increases. Notice my min & max speed and also how low the IAT temps have dropped.
This finishes my testing for today and my thoughts on this mod are. More low end power in terms of just driving around, Better mpg (seemingly) and the car accelerates faster when I step on it.
The estimated HP and Torque numbers above:
Pull 1 (modded) : 421hp 470ftlb
Pull 2 (stock) : 414hp 429ftlb
Pull 3 (modded): 426hp 488ftlb
So estimated hp and torque gains of
7-12hp
41-59 ftlb
Not bad for a 5 minute mod.
Ambient temp: 33f
Weather: Snowing
Date: 12/21/2024
(figure 1)
(Figure 2)
7-12hp
41-59 ftlb
