Pretty knock limited at the moment. Either E30 mix or stay with map1.
Thanks for the reply this is another map 2 log this time with e30. Does this look better?
The spark plugs are the HKS M45IL gapped to .022. The log I posted last Thursday was on 93, the log from last night was E30.This map is too much for your car/fuel. What spark plug? Gapped? Fuel?
Try to reset your trims settings, drive normally for a while and reloge.
Will do, thanks for the help.If you have Ek1, you can use it. If not, disconnect your battery (-) for 10-15 minutes.
Sometimes, it helps. But remember to drive for a while (like 50 miles), making gentle pulses. You can display the corrections on the JB4 app Ign2-6 and see how they change with each pull.
So I disconnected the battery as instructed and did some driving around in map2 before doing some 2 pulls. Is this looking better.To reset ECU adaptation settings You have to disconnect the battery for 10-15 minutes. It should help. In memory, there are settings from the previous spark/fuel. By doing this, you accelerate "new teaching".
There should be no reason to have with HKS and 93/E30 corrections like that. You can log map0 and see what your car is doing in the "stock" mod.
Yup. That 0.8 deg is adaptation period. So it's absolutely clean now.So I disconnected the battery as instructed and did some driving around in map2 before doing some 2 pulls. Is this looking better.
So the 3’s in cylinder 6 are nothing to be concerned about? Trying to learn more about this as I go.Yup. That 0.8 deg is adaptation period. So it's absolutely clean now.
Very minimum comparing with where you at before. What plugs and gap are you running?So the 3’s in cylinder 6 are nothing to be concerned about? Trying to learn more about this as I go.
Just get the newer style ones from lap3 or lozic. They're amazing.HKS .022.
This may have nothing to dye with anything but when I put the plugs in I broke the coil pack on cylinder 6 and replaced it with an Amazon cheapy.
Adding those to the cart now. In the meantime i’m all set to stay on map 2 correct?Just get the newer style ones from lap3 or lozic. They're amazing.
Yup.Adding those to the cart now. In the meantime i’m all set to stay on map 2 correct?
HKS .022.
