Maybe they are saying that because of the rear tires being the wrong size/OD? They don't want to hassle this any further"
You forgot to say what size tire your trying to runI have a 2023 GT-Line AWD. Continental says these tires won't fit. I see people here running them. What gives? Be nice, I know jack about wheels and tires.
Whatever works on the car. That's the thing - the sticker says 225 45R18. Not a size for the DWS06+. But I still people here running them. How? Aftermarket rims?You forgot to say what size tire your trying to run
Not 100% positive (as I haven't done the research) but is it possible that the reason why they are showing up "not fitting" or "not compatible" is due to the load and/or speed rating? I'm not sure exactly what all the options that are available for the DSW06+ in 225/45 R18.
Edit: After doing some checking, I think it's the load index. The DSW06+ load rating for the 225/45R18's is 91 (1356 lbs) and the Stinger supposedly requires a load index of 95+ (1521 lbs). It looks like that's the only option. So my guess is they're not "compatible" due to load.
Maybe not the same vehicle setup as you?Yep, that looks like the reason. Wonder why people are running them here... sounds kinda dangerous.
see: https://stingerforum dot org/threads/continental-dws06.24709/
The link you attached doesn't' work for me.
I had them on my 2018 GT2 RWD.
Ahhh, yes...the old "dot" "."Replace the "dot" with a dot...
