Inches?First off,love the platform. 2021 GT2 AWD. 19” staggered. Have found myself with tires that are .2165 difference in diameter. Should I just try and sell two of them
Inches?
0.2165" sounds extremely close.
What are the tire sizes? What's the % difference.
Yeah the decimal is splitting fine hairs. It was the difference in the two tires when I plugged the number into the calculator. .2 was also the difference on Bridgestone site.What got me started was a post I read concerning Differential light on shortly after installing tires at a .5 difference. Was advised to quit driving,have it towed. Remove AWD fuse etc..So now I’m freaking out a bit. At what point above the .1 factory spec do you start worrying about eventually taking out the differential. A great deal on tires won’t constitute toasting the diff.Tire sizes are 265/35R19 and 225/40R19. Stock rims for now. Looking for an aftermarket wheel replacement which brings an other set of issues. Geez I thought wheels and tires would still be a relatively easy issue. NotMaybe I'm reading this incorrectly, because I don't know how you'd measure a diameter difference out to the third & fourth decimal (the variation in the tire itself would be more than that, not to mention wear would constantly change it), but if it's 0.2" difference in diameter, that's pretty minimal. Stock staggered wheels/tires have a 0.1" difference.
Surely by "differential" you mean transfer case clutch. (I sometimes call it a center diff, but it's not)Yeah the decimal is splitting fine hairs. It was the difference in the two tires when I plugged the number into the calculator. .2 was also the difference on Bridgestone site.What got me started was a post I read concerning Differential light on shortly after installing tires at a .5 difference. Was advised to quit driving,have it towed. Remove AWD fuse etc..So now I’m freaking out a bit. At what point above the .1 factory spec do you start worrying about eventually taking out the differential. A great deal on tires won’t constitute toasting the diff.Tire sizes are 265/35R19 and 225/40R19. Stock rims for now. Looking for an aftermarket wheel replacement which brings an other set of issues. Geez I thought wheels and tires would still be a relatively easy issue. Not
I’m not running a staggered setup on this car KIA is. The diameter was acquired through a general calculator found on line with plugged in tire sizes. Manufacturer varies. Checked against the manufacturer it was the same .2. In hind site should have bought all four the same size with different rim widths and called it a day. I’ll post these tires on facebook and move on.^^You're running staggered on a awd car?
Using a tire calculator based on tire size is erroneous. You need to look at mfg specs for said tires which will generally have actual tire diameters (for a given wheel diameter/width).
What interesting, given the mfg spec, for say the tire in my sig, ps as4, 245/40/18;
overall diameter = 25.9"
revs/mile = 803
measured rim width = 8.5"
1 mile = 5280 ft
Circumference = 2πR
So, 5280 ft/ 803 revs/mile *12 inches/ft / π = 25.12" inches for a diameter. This is different than their spec of 25.9". So which diameter is correct¿?
To keep confusion to a minimum, running the same size on all corners and call it a day.
What width would that be? If you ran 225 square, wouldn't the narrower tires in the rear make them wear out even faster than OEM staggered 255 do?...should have bought all four the same size with different rim widths and called it a day.
the factory staggered should be 225-40r19 front and 255-35r19 rear... i'm running 235-40r19 and 265-35r19 on rear on factory wheels now for about 40k miles now with no issues. of course if there are individual brand tire size discrepancies that sucks...I’m not running a staggered setup on this car KIA is. The diameter was acquired through a general calculator found on line with plugged in tire sizes. Manufacturer varies. Checked against the manufacturer it was the same .2. In hind site should have bought all four the same size with different rim widths and called it a day. I’ll post these tires on facebook and move on.
No, NOBODY does that.In hind site should have bought all four the same size with different rim widths and called it a day.
Hmmm, why not? I'm planning to do exactly that with the OEM rims and 235/45r19 snow tires next winter.No, NOBODY does that.
Since you are not able to rotate your wheels, there really is no point to using square tires on staggered rims..Hmmm, why not? I'm planning to do exactly that with the OEM rims and 235/45r19 snow tires next winter.
The tires are brand new and the OEM rims are 8.0 and 8.5, so I'm betting the .5" stretch/squeeze doesn't throw the OD out enough to trigger an AWD fault.
Square setup, works well, when you can rotate your wheels for even wear.
You should trade me your 8.5" rears for my 8" fronts, and then you can have a nice square winter setup that can be rotated...Gotcha, my winter driving is pretty sparse, the tires will probably expire before they wear out. I drive an 18" square all season setup the rest of the year for my rotations.![]()
It's more than just the ability to rotate wheels/tires.Hmmm, why not? I'm planning to do exactly that with the OEM rims and 235/45r19 snow tires next winter.
ah.. so the factory size staggered is about a 5mm circumference difference (front 5mm larger circumference than rear) my set at 235/40r19 265/35r19 is about 8mm larger front to rear difference. So i could see possible issues if the rears are worn and fronts are new at that size... hmm.Official guidance from KIA is that the front/rear circumference should be with 10cm of each other to prevent AWD issues. TSB10242913
Must be a hell of a lot of rounding going on on sites like Tire Size Comparison if Pi is still 3.14159265359.ah.. so the factory size staggered is about a 5mm circumference difference (front 5mm larger circumference than rear) my set at 235/40r19 265/35r19 is about 8mm larger front to rear difference. So i could see possible issues if the rears are worn and fronts are new at that size... hmm.
