The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Advertise with us!
Promo code: REDLINE
Did you replace the front struts yourself? If so, what was the process? Thank youAny updates on any of this????
I just replaced the front strut mounts and struts - noticeable difference all around
YES!!! SO HAPPY FOR YOU!!! Seriously glad that this worked out in your favor and will be doing mine very soonI had my control arm bushings replaced and have been problem free since then. Only replaced the large ones from the rear curved control arm. These ones.
I did them at 135K km and now have 163K km. Car still drives like a dream
View attachment 81166View attachment 81168
Thanks for responding yesterday Calvn - I'll put up a new thread on the forums, I have a few important mentions that every stinger owner will find helpful. Not sure when i'll go about this - is this information you need right now?Did you replace the front struts yourself? If so, what was the process? Thank you
I'm installing coil overs this weekend and will be disconnecting the control arms so not vital just curiousThanks for responding yesterday Calvn - I'll put up a new thread on the forums, I have a few important mentions that every stinger owner will find helpful. Not sure when i'll go about this - is this information you need right now?
What noise(s) did you have. Any way to describe it? Trying to figure out my noise now.Just adding some info here for anyone else with similar symptoms. My suspensions was acting up, lots of noises, dealer inspected the bushings and said all LOOKED fine. After replacing the lower control arm, #10 on the diagram, one of the noises went away. Then they replaced the upper strut mount and the other noise went away.
Point is, visually the bushings may look okay, but sounds like that may be a problem as the stingers get up in mileage.
I have 58k on my 2018.
Control arms sounded like metal decompressing, high pitch metal on metal screech. The strut mount (ended up replacing mount too) was a deep low thunk)thud Started out very mild and eventually became every bump in road. It was like someone hitting the underbody with a baseball ball. Sway bar links make a similar noise.What noise(s) did you have. Any way to describe it? Trying to figure out my noise now.
Have you done those bushing upgrade?If you want to know just how much these suspension bushings get stressed, take a look here. The below pic is me at the end of threshold braking, and starting to trail brake into a left turn. Notice how much the front wheel is pulled back. That is the OEM soft rubber bushings flexing BIG TIME. Even the rear wheel does the same, but to a lesser degree.
Those Superpro bushings are definitely a good idea for tightening up the front suspension, albeit at the expense of some reduction in road isolation. BTW, Whiteline also offers the same: Radius Arm Lower - Bushing Kit Double Offset
stingerforum.org
I assume these have to be pressed in?It's on the short list. Hopefully, soon.
Yes, you'll need a hydraulic press to R&R. Same as the other front bushing. 54551-J5000 - Lateral Arm Bushing 2018-2023 Kia Stinger | Kia Cheap Parts I might get OEM replacement bushings for those to change out at the same time.I assume these have to be pressed in?
If I remember correctly, in order to remove that straight arm you have to lower the steering rack, because arm bolt will hit the rack before you can take it out. No need to do anything to tie rods, unless they, for some reason removed tie rods from the rack!! in order to remove that bolt. Make sure all 4 steering rack bolts are back and torqued.Went back. They mentioned they had to disconnect the tie rods to get to the arm but that everything should be fine.
Ok, but to happen while they are working on the car?! What could trigger it?Your car is no more cursed than any other at 163,000+km (100,000+ miles).
Pile on the miles, and stuff will start to break sooner or later.
Thanks! I will check tomorrow, although I expect them to have done it already.If I remember correctly, in order to remove that straight arm you have to lower the steering rack, because arm bolt will hit the rack before you can take it out. No need to do anything to tie rods, unless they, for some reason removed tie rods from the rack!! in order to remove that bolt. Make sure all 4 steering rack bolts are back and torqued.
