Dragonzsled
- Mar 23, 2018
Ive been reading the forums and posts of members using heat guns to loosen the factory adhesive. I didn’t use one on my car nor do I recommend it for the novice. You can remove the badge and the adhesive without heat gun it just requires a little elbow grease and some Rapid Remover. RR is a solvent that we use when removing vinyl art or lettering from vehicles. It dissolves the glue and does nothing to paint. It takes a little work but saves a trip to body shop, unless you have a defect to begin with. JMO
