Is the fuel you use the same for both logs?I am sending another log on another ECU from Lozic. Which one to choose?
Yes, great explanationSo after you put the new ECU in it will go through the “adaptions value” phase. Basically a learning phase for the ECU. The ECU is learning what fuel you have and all other outside factors. It does this before fully advancing the timing and allowing the car the most power etc. Hopefully that made sense!
So in the log IGN 2-6 will show 2.3 on all cylinders at first. Then after a few pulls it will go down to 1.5. Then a few more 0.8. Then a few more 0.0- then it is “fully reset” probably not the best terminology. Sometimes this takes 3/4 tank unfortunately. But once that happens the log will show you the true potential of the tune and also any issues. Also will be faster usually then too.
I think it’s unfair to say one what is better untilUnfortunately, the first one is 100 octane Shall Racing, the second one is a 98/100 mixture.
Damn, I did not know this.. I always wondered why I would these specific values. I was recently told there are different calibrations from the factory and some pull 2.3 by default and other calibrations 0.8 by default. Lozic I was told uses the c7c calibration for all of his tunes. That's a Stinger tune from what I understand.So after you put the new ECU in it will go through the “adaptions value” phase. Basically a learning phase for the ECU. The ECU is learning what fuel you have and all other outside factors. It does this before fully advancing the timing and allowing the car the most power etc. Hopefully that made sense!
I’m recently going to plug back in an ECU. I’ll show the logs of each period and how long it takes.Damn, I did not know this.. I always wondered why I would these specific values. I was recently told there are different calibrations from the factory and some pull 2.3 by default and other calibrations 0.8 by default. Lozic I was told uses the c7c calibration for all of his tunes. That's a Stinger tune from what I understand.
apples to apples on fuel and ECU not in the learning phase. But I really like both those tunes! They hold boost really nice. And timing is good but not crazy aggressive.
1. What were you told was different about each tune?The first log was shortly after changing the ECU. The second log on another ECU was made after a few days of testing. What do you recommend? I must choose
Hi,1. What were you told was different about each tune?
2. Did you just ask for 1.5? The reason I ask is most 1.5 I have seen drop boost a lot more than yours does after 5.5k rpm.
That being said out of those two logs and limited data- the first log you posted I think has more potential for faster times and a touch more
Power. But the second log looks to be a little more conservative/“safe”
Text me at (801) 318-2380 to review.Hello, I 'm sending a new logs from today, methanol 100%. What do you think?
Regards
Bogdan
OkThrowing this out there to all
People that have CPI.. when pushing 20-22psi of boost. And below 1/2 tank of fuel. Do you ever get Fuel Cut/crash? I believe I know why. I just wonder how many others experience this…
Depends on what you want. Most advise to use jb4 to log anyway. With 91, I don't think you'll get too much more than jb4 map 2, but maybe I'm wrong. As for ecu, not sure I'd go lozic at this point, although lap3 stage 2+ needs wmi, I think. I'm not willing to do wmi.So there’s no point in getting an ECU ?
