Installed in under 5 minutes, super easy. Plug and play all day. Just follow the instructions on the n54tech website and you’re good to go. Sticking with the default map for now, might try map 2 soon. Map 2 I believe is an extra PSI.
How do we change the maps? Are instructions in the box? How many maps are there and what are their differences?
I emailed them, and they said you can use it with completely stock vehicle as of now, of course it is still being tested.
Keep in mind LAP3 said the same thing at first.
BMS is letting us know up front that these are testing units and they aren't certain about anything.
There are 3 maps. Map 1 is 3psi above stock, map 2 is 4psi over stock and map 3 is user adjusted boost.
Very interesting. As you can tell I'm new to BMS tunes. I'm assuming these are adjusted via laptop?
  • Like
Reactions: GTB
Does it require upgraded spark plugs and destroy coil packs on your brand new car like my lap3 chip did?
I'm slightly under the impression that lap3 released a bad tune, Kinda seems like they rushed for a grip in the market. I may be completely wrong, just writing whats on my mind. :whistle:
Mine is out for delivery! Excited even though I'm going to TRY to wait until my first oil change to install it. (900 more miles)
  • Like
Reactions: GTB
Nice I should get my next week sometime. I'm looking forward to install it
I've got to call in a couple favors before I get started on mine. If all goes well (and I can get an update) I'll probably be able to get some pre and post sensor data logged while I run the chip as well
their tune was ready long before anybody elses. so i get you're right.
Since i have the patience of a child on Christmas Eve I've decided to install mine today instead of waiting.
The obligatory "got the box" pic.
Annnddd I was going to do a write up for the install but it took less than 2 minutes so it's not even worth insulting anyone's intelligence.
I just did a couple of 0-60 runs. Using some cheap video editing software to view the videos by frame my 0-60 time is 4.29.
This is with the default map.
