socalvn
- Feb 9, 2022
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
That looks really good!Updated lowered pic on 20s View attachment 80160
If it really bothers you, you can take them to be machined down.Front view very slight poke in the rear could have gone two or three millimeters more on back spacing
I'm thinking about that. not having any rubbing issues. I really researched before purchasing so a bit disappointed.If it really bothers you, you can take them to be machined down.
We have the same spec rears, and I've been thinking about taking 5mm from the rears for a total offset of 50.
Most days I look at them and think they're fine, but then sometimes I'll think taking the 5mm off and they'd be spot-on perfect.
I have been running these for a little over a year. They never stop dropping lol. My rear wheels are now tucked inside my fender because they are sagging so much.This is my third lowering spring and finally I found the right ones. As most of you know all the lowering springs available are built for the AWD, so on the RWD the car looks like it is squatting.
H&R recently introduced lowering springs for the RWD (Part #28701-2) and the drop and stance is very nice. The front is a little lower than the rear which is perfect, because once you drive it evens out and it will not squat too much if you carry people in the rear.
The fronts are a bit softer than the Eibach, but the rears are significantly stiffer. The car turns better and feels sharper for some reason.
You should never settle for less. Your springs are following the same moto.I have been running these for a little over a year. They never stop dropping lol. My rear wheels are now tucked inside my fender because they are sagging so much.
So the gold one is a stock Stinger spring? 1/2 Coil CutA pic of my 1/2 cut coil H&R vs. a normal Ark GTS rear spring..View attachment 80308
The gold was Ark and the cut H&Rs are blueSo the gold one is a stock Stinger spring? 1/2 Coil Cut
Damn she looks good!!! All of it!! What side skirts are those?Updated lowered pic on 20s View attachment 80160
M&S America SkirtsDamn she looks good!!! All of it!! What side skirts are those?
Beautiful CarHere is an updated pic with the 1/2 coil cut rear spring and now with lightweight and forged, GR Toyota Supra wheels! 19x9 and 19x10 with 255/35 and 285/30:
Thanks, btw, what would be expected running the 28701-1 (awd) set on a rwd G70? Is the front too high, rear too low, or just poor spring rate in the front for rwd?there isn’t
Not sure on a G70. But on a stinger, the front will have a bigger wheel gap. Hence it will look squattedThanks, btw, what would be expected running the 28701-1 (awd) set on a rwd G70? Is the front too high, rear too low, or just poor spring rate in the front for rwd?
FWIW, never have passengers or heavy gear in the back if that matters.
TIA
Thanks, don't want thatNot sure on a G70. But on a stinger, the front will have a bigger wheel gap. Hence it will look squatted
