Post #34, I mentioned your HPFP crashing. Yes this can cause overboost.So I messaged Lozic about getting a revised 1.4 bar 91 octane ECU. He wants me to do send another log with 93 only (have 2.5gal E85 right now) running map 0. He’s saying the overboost is related to fuel pressure. What are y’alls thoughts on this?
Another thing is to check if the fuel stations you are using serve "Top Tier" gas. Fuel is one of the most important things happening with your vehicle. This article should help if you are unfamiliar with the term:
What is Top Tier Gas and Is It Worth It?
Top Tier gas is worth it for some car owners, particularly those who own vehicles that require this type of fuel. Learn more about Top Tier fuels and who needs them.
I think at one time both @StingerbyAdoom and I were running the same settings from Lozic, in pretty much the same climate, time of year etc, but my car was running faster. Mainly due to fuel. I don't recall exactly, but his vehicle may have gotten a more aggressive setting later and it still wasn't enough because of the difference in fuel quality. Proper octane and quality fuel are extremely important. Please understand that you risk a lot by not having that right. I just don't want you to blow your engine.
P.S. @StingerbyAdoom I still owe you a run at NED. I'll make sure that happens this year if you're still up for it.
