Lozic ECU and JB4 map 6 log review
1.4 Bar 91 Octane running on E30. Is it worth it to play with map6 or should I remap for 93?
No don't even think about remap. Your current boost curve is so easy to stack 1-2 psi on top right now. Asking lozic to add boost wouldn't give you any better result other than a non~stackable boost curve that have same or weaker highend output
Well I tried doing a pull one more time and it did not go well lol. The boost got up to 28psi and while accelerating the car felt like it wanted to go faster but it was hesitating. I will be putting the stock ECU back in and run JB4 until I can get a revised ECU. Here is the log from that pull if anyone can give more insight on it. I know the 1.5 bar on 93 only won’t work, just wondering if fuel is the only issue here or something else too.
