Should I get fuel injectors and would i need an upgraded intercooler or any other parts?
You actually can run the JB4 off the diag port under the Hood. I've been doing it for a year now. Just gotta pin the right ports. Number 11 and 8 I think off the top of my head. The OBD2 connector is the same thing, just 2 pins going to the JB4 connector. the 3rd wire is a ground I am fairly certain, as it doesn't seem to effect anything on my car by not having it connected.
Yeah, I heard about that, did you find a connector that is compatible, or did you just makeshift plug into the right pins? If you have anymore detail, I would be interested.
I got some thin wire, stripped it, put it in the right ports, put the wire in a quick disconnect connector, and thats it. it just works. I havent bothered trying to find a connector that was compatible, though I suppose I could.
Do you happen to know the right pins? Might be a good how-to to post up here.
Not off the top of my head but I can look at some point. There is actually already a how to here on the forum, It just got buried a while ago.
OK, I will try and search for it.
If you are looking down at the connector it should be pin 8 and pin 16. But I haven't tested this myself, and can be wrong. So try at your own risk
