Kr33m0
Have there been any issues of shops installing those size tires? I had 235/19 & 265/19 on a 01 330ci and had to take them to specific NTB shops.
There can be, my local Discount Tire had no issues with it though. Give your shop a call to confirm.Have there been any issues of shops installing those size tires? I had 235/19 & 265/19 on a 01 330ci and had to take them to specific NTB shops.
you have a pic of how it looks? I am currently on 235/40/19 front, 275/35/19 rear but seriously considering 255/35/19 front, 285/30/19 rears I have Rohana RFX11 8.5" +32 front and 9.5" +40 rear. To be at stock height I need to be on 295/30/19 rear, 265/35/19 front which will not fit my current wheels without the tire bulging out. Not a look I'm ok with.I wanted to keep the stock wheels so was a bit limited on my tire options but, went with Bridgestone Potenza Sports; front 235/35/19 rear 275/30/19. I love the rears. Would have preferred 245 in the front but America's Tire wouldn't do it. I also just installed GRBS Coilovers. I might add some small spacers just to fit the wheels the rest of they way? Not sure yet.
Looks sweet. But you’re on 20’s. I’m attempting to widen the tires while remaining at stock height with 19’s.I'm running a square wheel staggered tire setup. 20x9 +34 wheels all around with 235/35 tires in the front and 275/30 in the back. I'm also at stock ride height.
I see. I was trying to stick with 19's back when I had to replace my tires but gave up because wide 19in options were a bit more Iimiting. So I gave up lol.Looks sweet. But you’re on 20’s. I’m attempting to widen the tires while remaining at stock height with 19’s.
Can you clarify your set up here? Are you saying this is stock height with 245/35/19 fronts and 285/30/19 rear? My rear tire is showing threads so I have to pull the trigger on some tires tomorrow morning. I am currently on 235/40/19 and 275/35/19 on Eibach's. I am considering 265/35/19 front and 285/30/19 rear. (maybe 295/30/19 rear) which will be spot on to stock tire height. I have confirmed the 265 will fit the 8.5" rim. The 9.5" rim max recommended tire is 285. If I go with a 295, the sidewall will bulge slightly. I saw that it fits on a Porsche forum as someone did the same set up of 265/35/19 and 295/30/19 but the 295 was bulging slightly and I am not certain I want that. I'd rather stick to the 285 if there isn't too much of a wheel gap.I’m on F: 19 x 8.5 & R: 19 x 9.5, 19 x 10 also should fit OK with the correct offset.
As for tyre size I was thinking of going up to 245/40/19 & 275/35/19 but my tyre shop was a lititle concerned that the increase of height up front my rub or scrape, so I played it safe & went the same, to be honest the ride quality never changed from OE sizes & I’m running Falken FK510 on the lighter weight semi-forged Koya’s.
The Avant Garde in the right colour would look really nice.
Just to add here is a side shot of the stance, remembering I’m at OE height.
To clarify I’m at stock height with 245/35/19 et: 32 & 275/30/19 et: 38Can you clarify your set up here? Are you saying this is stock height with 245/35/19 fronts and 285/30/19 rear? My rear tire is showing threads so I have to pull the trigger on some tires tomorrow morning. I am currently on 235/40/19 and 275/35/19 on Eibach's. I am considering 265/35/19 front and 285/30/19 rear. (maybe 295/30/19 rear) which will be spot on to stock tire height. I have confirmed the 265 will fit the 8.5" rim. The 9.5" rim max recommended tire is 285. If I go with a 295, the sidewall will bulge slightly. I saw that it fits on a Porsche forum as someone did the same set up of 265/35/19 and 295/30/19 but the 295 was bulging slightly and I am not certain I want that. I'd rather stick to the 285 if there isn't too much of a wheel gap.
gottcha. thanks for the quick reply. FYI, 255/35/19 and 285/30/19 is closer to stock tire height. To be spot on, the rear has to be a 295/30/19. Ride looks sweet.To clarify I’m at stock height with 245/35/19 et: 32 & 275/30/19 et: 38
Nice, so you have no rubbing? Post up some pictures.gottcha. thanks for the quick reply. FYI, 255/35/19 and 285/30/19 is closer to stock tire height. To be spot on, the rear has to be a 295/30/19. Ride looks sweet.
I will as soon as I get themNice, so you have no rubbing? Post up some pictures.
Oh, and no rubbing or scrubbing. Next is 295/30/19 even though not recommended for 9.5”
I want to possibly do the same, but I think I got lost in all the different setups, LOL! I guess what I am looking for is the best setup, on OEM 19" wheels, if I am looking to go a bit wider AND not be an issue for a tire shop. I think I am hearing 245/40 front, 275/35 rear is that setup. Is that correct?Looks sweet. But you’re on 20’s. I’m attempting to widen the tires while remaining at stock height with 19’s.
I believe the max width for the OEM stock 19 wheels are 245 front, 255 rear.I want to possibly do the same, but I think I got lost in all the different setups, LOL! I guess what I am looking for is the best setup, on OEM 19" wheels, if I am looking to go a bit wider AND not be an issue for a tire shop. I think I am hearing 245/40 front, 275/35 rear is that setup. Is that correct?
If this is the case, might as well go oem to avoid any headaches and upgrade if I decide to change my wheels later! Now to add to the fun, any recommendations on tires to replace the pilot sports?I believe the max width for the OEM stock 19 wheels are 245 front, 255 rear.
I went with Falken Azenis FK510 tires. Cheaper than the Pilot Sports and they perform wonderfully. Good in the rain as well.If this is the case, might as well go oem to avoid any headaches and upgrade if I decide to change my wheels later! Now to add to the fun, any recommendations on tires to replace the pilot sports?
Max you can run on OEM 19's is 245s front and 275 rears (but confirm with your tire shop that they are ok with installing on a 8.5" wheel).If this is the case, might as well go oem to avoid any headaches and upgrade if I decide to change my wheels later! Now to add to the fun, any recommendations on tires to replace the pilot sports?
The software update on the site did that, apparently, since this started then. Resize the pics and upload them again.Not sure why pics are uploading sideways.
