Here are the parts I used Fuse tap Switch
I also got a spare cover so I could put the stock one back on if I don’t need it which I probably don’t anymore since I bought a Lozic TCU from a fellow forum member that has the LC torque limit disabled.
Hey man I was reading thread and did the exact samething you did but for some reason my fuse tap wouldn’t plug in to the 10amp that was removed. As if it was to big. Did you not come into that same issue?
Hey guys sorry may have been answered already but when using the break snip method do you get all kinds of cel's? I just did it and every check warning light and blind spot warnings were coming on! And like you said I turned it off and back on and the lights were all gone. I just was curious if you do get all those warning lights coming on. Thank you in advance!
