Rodtheviking
Honestly the best thing I have done recently was get a pedal tuner, really smooths out the pedal response.
So the pedal tuner outweighs the drop Springs and the sway bars and the end links and the camber arms as "best thing" recently?Honestly the best thing I have done recently was get a pedal tuner, really smooths out the pedal response.
Personally I think that Product you tested for me is the best thingSo the pedal tuner outweighs the drop Springs and the sway bars and the end links and the camber arms as "best thing" recently?![]()
The sways are pretty nice too..So the pedal tuner outweighs the drop Springs and the sway bars and the end links and the camber arms as "best thing" recently?![]()
Only on threads with you in it!Okay. Do you keep this stock observation on your clipboard to save yourself posting time?
Technically...no a catback exhaust doesn't void your warranty. By law they need to prove whatever aftermarket change you made is the direct cause to a failure. That doesn't stop the dealership from trying to claim your aftermarket part is the cause...even if it's not. Since it's cat back...it doesn't effect any of the emissions components so you're good for smog checks.
A catback exhaust will not void warranty, nor will it fail a smog test. If you get rid of the cat's then you could fail smog, and Kia could raise a stink about it if something failed that could link to it.
Thanks all, just ordered the MBRP S4704AL. Hopefully it will make this car loud!3. No, it won't void your warranty.
You will want to get exhaust tips from ali express or other site. I believe it is 63mm inlet and 105mm width outlet.Thanks all, just ordered the MBRP S4704AL. Hopefully it will make this car loud!
Also didnt know what a kickdown switch was. Thanks
I dont like to play the "free tool rental" con, so would just keep the ramps; however, I agree to just do the exhaust yourself. No special tools needed, just sockets/wrenches to unbolt the old catback and install the new.How about free? Buy a set of ramps from Walmart, change out the exhaust, dust them off and return the ramps to Walmart. Save $150-300.
I don't know if I'd call it a "con." Walmart doesn't have a policy against returning used items. As long as it isn't damaged, returning it is totally within their return guidelines.I dont like to play the "free tool rental" con, so would just keep the ramps; however, I agree to just do the exhaust yourself. No special tools needed, just sockets/wrenches to unbolt the old catback and install the new.
You are using something for free, and then either Walmart eats the cost (and by that I mean their customers), or they pawn it off as "new" and someone else pays full price for used merchandise.I don't know if I'd call it a "con." Walmart doesn't have a policy against returning used items. As long as it isn't damaged, returning it is totally within their return guidelines.
However, I prefer to add on to my tool collection, too, especially something like ramps that can be used many times over the life of many different vehicles.
It's not ethical though, which was boosted's point. Ethics and legality are two different things. I prefer to be ethical, others ramrod through life cutting every corner they can. I sleep well at night, they are typically disgusting human beings making numerous similarly bad choices resulting in chaos and dissatisfaction.I don't know if I'd call it a "con." Walmart doesn't have a policy against returning used items. As long as it isn't damaged, returning it is totally within their return guidelines.
I didn't either, until over a year into this car.Also didnt know what a kickdown switch was. Thanks
Then blame others/make excuses for the outcome of their bad choices....others ramrod through life cutting every corner they can. I sleep well at night, they are typically disgusting human beings making numerous similarly bad choices resulting in chaos and dissatisfaction.
If you're on the West side of the city, you can see if Sun Auto will do it for cheap.Hopefully I can find a place to install it for a fair price, I've been quoted everywhere from 150-300 for the catback, so I'm not sure what is reasonable, what is good, and who is ripping me off.
The Donald Trumps of the world. And there are many. So sad!Then blame others/make excuses for the outcome of their bad choices.
You are using something for free, and then either Walmart eats the cost (and by that I mean their customers), or they pawn it off as "new" and someone else pays full price for used merchandise. Either way you are cheating the system for your gain at someone else's loss.
