so 1.4 bar is just over 20lbs of boost. I assume you are logging with a JB4 to see peak boost? also to confirm timing is not being retarded?
with the stock ECU, the "comfort" setting basically changed transmission logic, IE quicker shifting to higher gears, as well as reduce throttle response, lighter steering, softer damping, etc. With this Lozic tune, was he also looking to reduce boost in Comfort, vs sport, vs smart, vs. eco, etc.?
Logically I would think if you floor it in any mode, you should get max throttle, max boost, etc., right?
Also, does it even matter what peak boost is in comfort mode? you wouldn't be driving it all out anyway, and with RPM's not building as high based on the transmission shifting sooner, you won't get to peak boost anyway, right?
Also, JB4 map 2 typically peaked around 18/19 lbs of boost, which is really the limit of 93 octane. If you are running good 93 octane, then you are at the limit as far as timing goes.
