Vilithrax
- Mar 17, 2022
Does the Borla catback come with tips that are sufficient?Plenty of exhaust options out there, but you WILL need aftermarket tips as well or the drone will be awful. also, a dedicated ecu tune or the JB4 will stop the car from over-boosting for the most part with no cats, but it will probably happen every once in a while regardless. your best bet is to get sport cat primary downpipes then straight pipe it from there if you really want noise.
We plan to go high flow primary with secondary cat delete but are having a hard time finding straight pipe catback. Does someone make that or do I need to custom fabricate from the Borla?
