JSolo
2500 Posts Club!
^^How'd you route the wires for the charger?
If your car is not equipped with idle stop and go (stop start), it is unlikely to be equipped with the more expensive and more robust AGM battery.Hi,
Yes, mainly short trips tbh. Rarely do more than 30 miles in one go.
I’m not quite sure whether the current battery is an AGM..is there a way to tell other than if it says AGM on it?
I have just noticed that the new battery that I have just reserved at the store appears to be a non AGM battery, but when I put my registration number in, this is the one it recommended.
So is mine (2018) - Canada 3.3 turbo AWDYep, gonna get the new one installed tomorrow. Mine definitely doesn’t have AGM written on it, so I guess it’s a ‘standard’ version’.
The car is a 2018 btw.
Thanks for all the advice.
Valid concern. The mfg doesn't know what kind of charger end user will use. Will the use a maintainer or a charger. I can see overcharging having potential for fire. Also ventilation plays a role. If my garage was detached, I would not be comfortable charging any battery within unsupervised.Hey Don, this is not my wheelhouse but I know the reason I was given for removing for charging was the potential for fire. Even though there is a low probability of it happening, it can happen!
You must be a hefty bloke then. There is no way that I would risk my back or a hernia lifting out a dead battery this big and reversing that with a new one. The removal of the "fuse box" and managing of nuts and bolts, etc., I think I could work my way through carefully.I actually fancy doing it myself.
It does not need any "Coding" or programming.Don’t know if the battery has to be programmed/coded. I know BMW and Audi do.
The procedure to reset AMS is to just shut the car off for 4 hours? Is something missing here? I plan to use my XTool to go and reset AMS, or what XTool calls "BMS" after replacement, but was curious about this procedure you posted anyways due to its suspicious simplicity.The owners manual says to charge it by removing the battery. The only reason(s) is an ABUNDANCE of safety/liability
The service manual says to charge it in the car (the Kia service manual), this assumes some basic knowledge so you don't blow yourself up or cause a fire.
If you were curious about how to calibrate the battery sensor, it is just about the easiest procedure of all procedures. (The acronym "AMS" is Alternator Management System).
The description of the battery sensor - it is basically a current meter that can monitor the current in/out at the battery + temperature and voltage.
My screenshot game is on point
Hi there,
My Stinger GT hasn’t been driven for 2.5 months and it wouldn’t start the other day. I have managed to jump start it, drove it for a couple of hours and then turned the car off. It wouldn’t start again. I have a trickle charger which may help to fix the issue, but I’m not altogether sure how to connect the crocodile clips to the battery, which I’ve found in the boot. Is it just as simple as connecting the red leads to the positive and the black to the negative or do you have to connect the negative to somewhere other than the battery itself? I am trying to avoid buying a new battery.
Thanks for your help.
No need to reset with any "tool" just wait approx. 4 hours with the vehicle off, and doors/hood closed.The procedure to reset AMS is to just shut the car off for 4 hours? Is something missing here? I plan to use my XTool to go and reset AMS, or what XTool calls "BMS" after replacement, but was curious about this procedure you posted anyways due to its suspicious simplicity.![]()
