DustinCheeks
- Sep 24, 2021
Thank you!Part # 81738-J5010QQK which I ordered here. It’s a set of two thicker foam pads plus 8 washers.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I installed the kit last weekend. Don’t forget to also check and adjust the anti-slam bumpers on the bottom of the hatch. Mine had moved in a bit.My kit came in the mail yesterday so looking forward to install this weekend.
Still quiet. Felt is holding up fine.Figured I'd follow up on my "fix". It's been 2 weeks and I haven't heard a peep out of my hatch.
Same hereStill quiet. Felt is holding up fine.
I got it for about $2.00 CDN from my local aKia dealer.Is this part only a few bucks from the dealer or are they marking it up big time?
My thought as well. It only took me about 20 minutes, including adjusting the over slam bumpers. I used a zip tie (between the rubber sleeve and bolt head) to make sure they stayed at the correct length.Cheap enough. Not worth the aggravation of dealing with service to get this covered under the tsb.
Yes. The bolts were actually a little bit loose (easy to turn) and had moved in a bit. The zip tie around the bolts tightened them up and got them to the right length. I used black zip ties so they are not noticeable .^^Over slam bumpers had to be extended slightly?
