This is a subject of interest to me. I bought a couple of faraday bags on Amazon, and the seller sent me another pair when my review criticized the workmanship. So, I had four bags for a couple of years. Earlier this year, I happened to randomly walk up to my driver's door with the fob in a faraday bag, and lo and behold I could push the black button and unlock the door. WTH!? I checked out the bag for any indication of loose seams to explain the signal getting through: nothing looked wrong with the bag. As I said in my edited review:
"Along with the crap workmanship, it appears that the faraday bag itself either does not work all that well, or it actually wears out over time. In either case, bag this bag."
Out of the four bags, that one (which I had been putting the fob into every night for over two years) did not work at all: one worked every time (the car lock would not respond to the bagged fob), and two were partially effective, in that sometimes the car could not be unlocked, depending on the angle the bag was held.
So, all of that is to give a warning that a faraday bag/cage is not guaranteed: test it before you depend on it.
I am still unclear on how secure our Stingers are: some things I've read assert that the keyless entry on this car is not easy to crack. That would be good. But nothing certain in that regard have I seen. Apparently, if the fob is in range of the car, (even a faulty faraday bag would probably severely reduce that range), a
scanner can read it and communicate it to the computer being used to open the car: once the fob is picked up, the replicated code sent to the computer from the
scanner convinces the car that the fob is right there and the car can be unlocked and driven away. So, the security, first of all, is to keep the fob outside of range: if that is difficult or impractical, a faraday bag/cage is the way to kill the signal the fob sends. Another expedient that I tried (read about and was skeptical) is to wrap the fob in foil: indeed, a fully wrapped fob in foil is completely blocked. So, I have my spare fob wrapped in foil. I supposed you could just use foil every night instead of a problematic faraday bag/cage, but that seems like a needless hassle.
