7Andrei7
Hi guys!
For the past year I've been struggling with a problem that my dealer is simply unable to fix. I have the 2.0 T-GDI.
When I start the car in the morning, the engine idles very rough when the car is in gear (D or R). The idle in N/P is normal. After the engine warms up (15 min or so), it all calms down and no more vibrations.
They assumed it was the engine so they changed: spark plugs, high pressure pump, all 4 fuel injectors. Checked a bunch of stuff.. and ended up saying it's the ECU's software that adjusts the idle and they can't do anything about the vibrations.
Now, looking at the engine idling in the morning, with the car in Drive (and only in drive), you can clearly see and hear the revs drop and the engine shuddering only to balance itself out immediately. Then, few seconds later, again. I am not applying any throttle. Just keeping my foot on the brake pedal with the car in drive.
Do you think it could be the engine mounts? I feel like it vibrates and moves too much for a rev drop of 800 to 600. The vibrations are very strong in the cabin as well.
Thank you!
Thank you!
