I pulled to a stop light the auto start stop turned off the car. I pushed the button to turn off the feature then my whole car went dead no dashboard lights come on and car won't start at all. Is this a known issue! My car has a recall on the wiring harness and I will get it checked soonhasn't had
2022 stinger gt1 awd, 2 months ago the start stop stopped working when pressing the gas pedal; it used to screw up a lot when it WAS working, everytime i went to put the car in park it thought i wanted start stop to work, so it would shut off real quick then car turn back on once in park to for parking. now ive got a weird metal screech noise coming from under the engine bay somewhere everytime i turn the car off.
also, the child window lock button no longer works- it doesnt lock the windows but the light comes on,
and the back drivers side window doesnt roll down or up after hearing a weird window motor sound for a day;
i hardly ever used that window, but im thinking something got bumped around since the roads i have to commute on are all torn up from construction and bumpy. i read somewhere else that same window problem with stinger because of loose connection.
also im getting hatchback rattle again like i had with my 2020 stinger.
i had blackvue dashcams and magic pro installed thru the fuse box; im hoping this is not related.
ive been getting BATTERY DISCHARGE BECAUSE OF EXTERNAL DEVICES ever since blackvues installed with magic pro.
does anyone else's do this when braking? i start applying the brakes and then a few moments later it feels like the back brakes grab really hard making a not smooth braking. is that just inherent of having front and back brembos? do they not all grab at the same time?
its annoying, i cant ever get a smooth braking because i think when the back ones engage, its jolting.
" If your using Power magic Pro, it would be recommended to set it to 12v voltage cut off,
Since the Power magic Pro draws power from the cars battery the Car's on board Computer will think of the power magic pro as an additional consumers or addition accessory, that was not on the original calibration of the Car's on board computer, this means that the computer will think the battery need to charge and recover. But as long as the Power magic pro is not draining your car battery, your okay.
To solve it, you may go to your Dealership service center to configure the power management system, so they can calibrate and add the PMP
Or You might also use other alternative power source option like the Power magic battery Pack(B112) or Power magic ultra battery ( B124X), Since battery is an independent power source it wont trigger the the car's Power management system to give you a low voltage warning.
1. Power magic Battery pack- No hardwiring required.
Simply plugs into your vehicle’s accessory (cigar lighter) power socket.
2. Power Magic Ultra Battery recharges with ignition on and powers your dashcam when ignition is off.
Fast-Charging: the Power Magic Ultra Battery reaches a full charge in a record 40 minutes when hardwired (80 minutes if connected to the cigarette lighter socket).
Long-lasting: Parking Mode can last more than 24 hours with a single-channel BlackVue.
