Darth Puma X
- Jul 26, 2021
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I truly appreciate the reply. Can you help a novice out and inform me on what would be causing the timing issues?Timing was getting rougher as each pass went on. I think map2 is your max, and to continue I would look at running some ethanol as the norm, E27-E30 should clean things up and keep that motor happier.
bad gas. 93 octane is barely enough thats why hes recommending you add some E. Otherwise, use the same gas and move back down to map 1I truly appreciate the reply. Can you help a novice out and inform me on what would be causing the timing issues?
Octane. Lack of.I truly appreciate the reply. Can you help a novice out and inform me on what would be causing the timing issues?
So if I don't have access to e85, more boostane?Octane. Lack of.
.22Yes Octane is the number 1, heat will throw timing off also, summers are tough. I know you have HKS as listed but what was the gap?
Yes. Sorry.Did you mean .022?
How does this pull look? Any better?Did you mean .022?
Or this one?Did you mean .022?
Appreciate it. Didn't plan on anything higher than map 2 for now. It's possible the plugs are off, I gapped them myself and perhaps I missed it by just a bit. I was using the BMS gapping tool that they suggested.Hopefully Darrin will get back to you on this. Seems like a few of your cylinders are a bit off. Wonder if the gap is not great on those particular plugs. I wouldn't run any higher than map two. Just wanted to chime in so I get updates on this thread. still picking up knowledge myself.
Truly appreciate your time. I don't seem to be having stuttering or misfires, so I will go with the fuel theory for now and make sure I add enough octane boost this next fill up, I realized I wasn't adding enough before because I misread the mixing chart.Still has timing corrections so likely just subpar fuel or learned adaptions from a tank of subpar fuel. No big deal, just stay on map2.
Spark plugs and gap don't often cause timing drops unless it's so far off you're also getting misfires or stuttering.
