I'm really on the fence about doing the whole thing. But nervous about the language barrier and not much testing done yet. I'm hoping results start pouring in so I can feel confident and pull the trigger as it looks very promising
Yeah. I’m waiting like you. Also, I have some other mods I want to install. I’m working on WMI this week. And I want the HFC primaries installed before I send my sheet over (if I do it).
I'm still confused on the option sheet but I did ask lozic about flames and he said just put it in the comments section. Didn't mention if I did or didn't need other mods for it to be done
The language barrier isn't bad, I talked to him last night before he shipped mine out. I understood everything. He was going to ship it out the day before but he wanted to do more testing to be safe. He told me about my boost curve and how it reduces from 1.8bar to 1.5bar. Told me about his testing of my tune in the vehicle ( tested in a 2022 Stinger just like mine show me pictures of him at the gas station at 3 a.m. LOL) said mine runs smooth no overboost and timing and AFR look good. he told me with my build I'm better running race fuels than ethanol otherwise he would have to rework AFR and timing. Told me he's been testing this for 3 years. He did warn me about turbo longevity lol but I assured him I'm not worried. All in all he said it's OK to him so he'll ship. Communication has been quick and easy for me. He answers anything I ask. So far I'm good with the customer service from him. No complaints at all.
Thanks. This is actually what I want to see (help me decide between TCU only (because I have a JB4) or getting the ECU as well. I forget, are you getting the AWD tune (if you are AWD) too?
Anyone in here running in the mid or upper 11's and high 3 sec 0-60 and not using a brake snip want to share with me there settings? I can only muster a 4.47 0-60 and 12.63 @ 112.07 DA 2200 elevation 942 ft and 75 degrees. I have a ton of mods and think I should be about upper 11.s and high 3's. Any ideas, suggestions, tips, and tricks?? I have seen plenty of people with less running those times with similar conditions.
I tried to ask lozic but he gave me an odd response but how would I get it retuned if for example I dont have a aftermarket secondary downpipe on right now but did put one on down the line after I got my ECU what would I need to do?
2019 G70 3.3T Sport AWD owner with Lozic ECU and TCU. 93 octane 1.5bar map, with AEM replacement filters as my only other modification. As per Dragy, my best 0-60 time is 3.62, and quarter mile is 11.79 @ 116MPH.
what was your DA, elevation, and temp? Also plugs and gap? I'm thinking more and more about trying this out. But I show I'm making 22-23 lb of boost so I'm not sure why I can't get better times since that is maxed out on boost? You have the awd tune also don't you?
Seems that we have similar trap speed, (me 117,5) but you have lower time. Maybe it is the TCU that is the most difference as you can launch with boost.
11.25 DA was around 2200That was a 2nd gear launch at the drag strip without brake snip. The 11.02 is a regular 1st gear launch on full interior weighting 4135lbs. The last one was my best pull so far 1st gear stripped interior.
I must be doing something wrong since I can't get better times. Several of you guys are running much better times. My runs are on the street not track and map7 around 21-23 lbs of boost.. HELP LOL
