Hello dear forum,
my name is Philipp and I'm from Germany.
I've found your forum when I was searching for the Stinger Service Manual, which has brought many insights to me.
My odyssey has started 4 weeks ago. I've driven to my dealer for an inspection and many things have been changed: engine oil, engine oil filter, three air filters, gearbox oil.
After driving home (no errors have appeared, everything working fine), the vehicle was standing four days at the same place and was not moved.
Then I've started the vehicle again, and a bunch of error messages was showing up:
First of all, I seriously think the errors are NOT linked to the inspection, that's purely coincidential.
The errors are: Front Collision Assistant (FCA), ESP, MIL, EPB, AUTO HOLD, and Start Stop (A) is flashing.
Most interesting: the RPM gauge (tachometer) is not working anymore and stays at 0 RPM.
Driven again to the dealer, and his diagnosis tablet has shown five error codes (translated from German):
P033500 crankshaft position sensor A, CKPS
C164808 erros CAN signal ECM/EMS for ACC/SCC
C136801 irreversible ESP error
C161381 error CAN signal EMS
B130487 error engine condition signal
First we've thought a marten (animal) has bitten though some wires, but nothing could be found. Surprisingly, the car drives pretty normal with some little bucking while shifting gears.
On spec, my dealer ordered a new CKPS and changed it one week later, but that did not change anything. Then the dealer said it will be complicated and he will contact the Kia dealer service.
Now, three weeks later, he still seems to be helpless, perhaps he does not want to help me because he does not earn money with me (everything is going on warranty).
Fot this reason, I've downloaded the service manual and could follow the electrical circuits (hopefully I've not done a mistake):
The high/low signal from the CKPS delivers the RPM to the ECM/ECU (connector A):
From there, the information is converted in the ECM/ECU and transmitted (connector K) to the instrument cluster and the IBU.
The IBU itself delivers the information for the CAN bus.
In my opinion, the dealer should check th pins 68/69/70 from ECU connector A with an oscilloscope to see with the CKPS is really working correctly or wheher some wires are damaged.
If everything is OK with that, he could check if the the engine speed output signal (pin 72 + B+) is working correctly. If not, the ECU is damaged. If yes, the wires the instrument cluster and IBU should be checked.
As I said, my dealer is not too helpful in the moment. Do you have any ideas to how to solve the issue? Perhaps only a simple fuse?
Best regards
Philipp
Best regards
Philipp
