Wilzer
Some may seen my previous post describing a problem filling the gas tank--back pressure kept shutting off nozzle.  Came on gradually and got progressively worse.  Took my Stinger to Crown Kia and Sherry the service advisor took my Stinger in for evaluation and verified that problem was as described or worse.  Kia trouble shooting central advised to reoplace the gas tank, as they thought it was a sticking ORVR (whatever that is).  Gas tank replaced but problem continued so they looked down the fill pipe and...
"There was separation in the fuel neck tube that connects fill neck to tank, removed hose and verified hose internally collapsed"
Fixed, picked up my Stinger today and on the way home, filled up with pump nozzle on automatic--no problems
Thank You Sherry
Thank You Sherry
