Please check JB4 logs
This was Map2, E25, brake snip, and ewg cables. I ran an 11.77 on dragy.
So what do we need to be looking for on our logs? The one i uploaded the ign2-6 only had a handful of 4.5, the rest was under 3 for most part.
This one you uploaded looks to be almost always in double digits, which is correct haha i have no clue.
They are double digits because my FUA was set to 1. Basically it's showing true timing. You're looking for spread between each cylinder. An easier way to read it is setting FUA to 0. Then, cylinders 2-5 will be at the bottom of the screen (0) and only deviations will be shown. For example if cylinder 2 and 4 pull timing because of knock, you will see those lines above the 0 on the bottom depicting the amount of degrees pulled. Read this, JB4 Logging Parameters - N54Tech.com - International Turbo Racing Discussion
Awesome, appreciate your help. Maybe I'll be as quick as you sometime in the future ;)
Looks good, should be fine for map3. Might even be able to get away with FF = 60 to push boost up a bit more on each map using the EWG connections.
Thanks for posting that log. That really helps everyone else see what a good run looks like. Was that with WMI running? I noticed it says "MethSafeMode = 1", "MethAdd = 75", "MethScale = 60", and "MethPSI = 6" in the header. Doesn't that mean WMI was running? I have zeroes for all of those fields except for MethPSI. What field signifies that Meth is running?
Those setting just carry over to the csv. No meth on that run. There is a meth flow column "Q" you will see all zero's. Just Map2
Where do you get your E85 to mix with 93 from? Is there a website that helps find E85 in NC?
There is a Sheetz in Fay so I'm lucky. Download Gas buddy app. It's map and gps driven and updated by users. Sort of like Wase, I use it to find diesel when I'm out of town
