AristotsirA
I have the Borla's on the way. I like the round more-so than the oval. When you say "some grinding"...how much we talking here?
I'd estimate the oval cutouts in the rear fascia are approximately 110 mm (W) x 80 mm (H), so any circle greater than 80 mm diameter will not fit, particularly if the mounted exhaust outlets are not perfectly centered. This will require some bespoke carving with a rotary tool like a Dremel (use masking tape or similar to prevent/minimize paint chipping on the modified surface) either above or below the existing cutout, depending on actual fitment to the exhaust.
For the Borla tips themselves, they appear to simply replace the OE integrated tips and not mount directly to the Borla S-type exhaust outlets, so installation shouldn't require any trimming.
Instructions can be found here: https://www.borla.com/A-35962.pdf
