I bought mine on Ebay and had them in 5 days. $85/each pair. 63mm x 89mm you need to Dremel a little bit in the bumper - the 63mm x 105mm supposedly you don't (I have the 63mm x 89mm - wanted the round look).
I have an ARK downpipe so that cut the drone some, but with the stock "tips" (I hate to call them that because they don't feel like what I think exhaust tips are), there was still drone. When I put on the tips I got from Amazon it cut down greatly, its still there not nearly as much though.
OD on the MBRP is 63mm, but you need to pay attention to what you are getting. Some will advertise as 63mm tips but they mean OD on the tips are 63mm and won't fit the MBRP (unless you "flub" it).
The stock tips don't actually connect to the exhaust. The pipes just sit in this bell shaped end and that form into the tips. The tips I ordered where from Amazon, and the same ones you find on Aliexpress (except your not waiting months for them). They came out to the same price because of free shipping.
If you have MBRP you need a 63mm ID, and then it depends if you go with the circle or oval tips. Circle tips will require some shaving of the diffuser (which sounds a lot scarier then it actually is), oval you don't need to.
With that being said you can rig up a 63mm OD tip if need be. My buddy didn't want to wait for new ones so we took the tips and butted them up against the exhaust pipe, we then used exhaust band claps with some sealant to seal around the exhaust pipe and tip. It worked great.
