Thoughts on the AC system
5tinger
How well does this AC cool compared to other vehicles?
No complaints, getting close to three years now. I think Auto works like gangbusters.
I was just telling my wife today how happy I was with the climate control system. I have set the temp, and I rarely even have to touch anything. Compared to our Fords, this works great!
does anyone notice that that when using the auto system, it's always on the outside air - I'm always having to manually pushing the recirculation button..
It only goes onto recirculate if you turn temp down low enough otherwise will be on fresh...
From: http://www.kstinger.com/automatic_ventilation-137.html
The system automatically selects the outside (fresh) air position when the climate control system operates over a certain period of time (approximately 30 minutes) in low temperature with the recirculated air position selected.
To cancel or reset the Automatic Ventilation
When the air conditioning system is on, select Face Level
mode and while pressing the A/C button, press the recirculated air position button five times within three seconds.
When the automatic ventilation is canceled, the indicator blinks 3 times. When the automatic ventilation is activated, the indicator blinks 6 times.
If the battery is discharged or detached, the automatic ventilation will be reset. Adjust the feature accordingly.
It could do a better job of filtering out the smells from the outside air. Apart from that it's great.
I meant that the system is predisposed to engage fresh air. Even when i set the temp to LO it does not switch to recirculation
Carbon filters capture odour.
I believe the G70 comes stock with one. However the Stinger comes with standard paper media.
Understood. The manual talks a lot about fresh air and passenger comfort. All evidence would suggest Kia values fresh air by default.
