StingaGT
But this is exactly what the GTS does. With the same components. The rear axle / diff are the same as the RWD versions save for those with LSD (Limited Slip Differential).
I was sceptical at first as well. This is not like other full time AWD solutions. Center diff torque transfer is variable from 0/100 to 50/50 based on the voltage/current coming in. Pull the fuse = 0/100
you will be putting excessive stress to the AWD transfer case by forcing every power to go to rear drive shaft.
