MANPADS
I was at about 2700 miles. The struggle I had with the filter is that you have a small hole to reach into in order to access it. Probably goes a lot easier with a 27mm socket - but I did not have one so I had to make due with my adjustable wrench. Very awkward angle to get good leverage.How many miles @ 1st change? Fumoto is awaiting install here. Any tips on dealing with the filter?
Every other part of the process was pretty easy, including installing the valve. It screws right in with no problem - I rotated the opening ~90 degress just in case it rubs against the engine covers
