DrewU272
If I update firmware from let’s say ver.11 directly you ver.16 will I get all data from versions inbetween? Or must each version be installed in sequence?
Hey Terry what’s the latest firmware version right now?Each firmware is fully self contained. Only load the latest.
Think it's up to 17. Planning on updating todayHey Terry what’s the latest firmware version right now?
And I saw I n54 only need the beta app if you’re on 3.7 Bluetooth? I just got mine but must have got an older one I’m on 3.6 BluetoothNo need, but good to use BETA app for JB4 mobile: Rev 3.7 Connect Kit App Compatibility Updates - N54Tech.com - International Turbo Racing Discussion
I would suggest you do some WOT pulls. Driving around logs don't cut it.Hi Terry,
I installed the JB4 unit with fuel wires, HKS plugs and loaded firmware 17.
Here are some logs driving around the city (stop n' go) - no highway action, too crowded yesterday.
How do things look? half the logs are on Map 1 the other half are on Map 2.
Thanks Terry,Only WOT logs are useful, set the app to combine them in to one file too much easier.![]()
1 hour interval is fine, default auto-logging setting is fine.
Full throttle 40-90mph for example on a race private track is good enough to evaluate.
Should be enabled by default. For JB4 mobile specific questions use the JB4 mobile support thread on n54tech.![]()
