2020KGT2
Where did you buy that material and what did you use to cut it?
Not the person you asked, but I just watched a detailing video earlier and came across this. If you have a pressure washer definitely worth it.I can keep my car clean in the middle of winter by using a bucket of hot water, right down to just barely above freezing. And if necessary I use a hand held wand wash to get extra grime off first, then I finish up at home. But, I cannot get the undercarriage; and road salt is the killer. How do you wash the underside of your car(s)?
Definitely going to do that. Thanks.The gutter mesh was at Home Depot for $3.69. I have wire cutters at home but they're maybe $10 if you need some. Made a quick outline on some cardboard cut the mesh slightly larger than opening, popped the small pastic keepers with a flathead 5-10mins later job done. Its super easy and a small insurance policy against rock chips.
Ohhhhhhhhhhhh...Something came todayyyyyyyy!!! Super excited for these!!! Having them installed on Saturday morningView attachment 41894
. Did you go with the soft setting all around? Do you notice a considerable difference? Wish I could put the car on springs like you did but living in a snowy climate it's probably not the best idea. Every picture I take of my car, all I see is wheel gap
.  Larger wheels might be in my future..This is the first time I've noticed that the holes are different sizes. What is the reasoning behind that?
Thank you, food for thought my friend! Reckon I’ll do some research on what sort of ‘wash chemicals’ they use in the laser washes here, because our laser washes come highly recommended! Like RedCal said, not much choice in winter, even though we don’t get below freezing very often, it does get bloody cold here! Anyway, I appreciate the input and advice from everyone, that’s why we’re all here on this forum! Also a good medium to meet good people with an equal love of our cars! Cheers folks!A member here operated a number of touchless wash facilities and would never put his Stinger through one. The chemicals used are not friendly.
The only thing that's touched my car since the factory is a dedicated wash mitt and clean microfiber towels. The dealer pulled the protective plastic and handed me the keys.
Thanks. But I don't have a pressure washer, and I seriously doubt that our domestic water pressure is up to that.Not the person you asked, but I just watched a detailing video earlier and came across this. If you have a pressure washer definitely worth it.
https://www.amazon.com/dp/B07RZYSL1Q/ref=cm_sw_r_em_apa_i_LkBVEbTZAM2CB
Thank you sir! Yes I love the look. Cleans it up a bit! I bought the measured and pre-cut vinyl pieces. About 30 min job...super simple. Here's the link if your interested. Search by Vehicle - KIA - 2018 - Stinger GT - Page 1 - Premium Auto Styling
nothing has the right to be perfect ..............................bawaaaaaa ,This is the first time I've noticed that the holes are different sizes. What is the reasoning behind that?
My best guess is the windshield washer reservoir tank may restrict space on the PS, but a little odd why they didn't match them.... who knows the designer??That is a very good question Marlin but for the life of me I have no idea. The drivers side is almost twice as large as the passenger side, why the disparity.
I've had these on for some time. Perfect fit and easy to apply, just be sure to squeegee all air bubbles out. The site has 25% off at the moment. For the bumper reflectors I just used a piece of black vinyl.I’ve replaced the rear reflectors with the LED Sequential lights from Sal so I don’t reckon I’ll smoke them out however, I will look into this website you sent me, especially if they are pre-cut to size. Makes the process somewhat easier I imagine.
Cheers Buzz, you’re a legend!
When you find out it may also explain why the grey padding on the underside of the wheel arches is also a different size.This is the first time I've noticed that the holes are different sizes. What is the reasoning behind that?
I'm trying to see what you're pointing out, and I am not seeing it.When you find out it may also explain why the grey padding on the underside of the wheel arches is also a different size.
Hard to see in the 2nd pic so here's another view of RHS. The silver stitched edge padding is about half the size of the piece on the LHS (1st pic)I'm trying to see what you're pointing out, and I am not seeing it.
Here's a related question: is the vent hole bigger on the driver's side of RH drive Stingers?
