That is not past the clear coat. So, no paint is required. You could fix this yourself. Use wet/dry sandpaper, at least 2000 fine, even finer would be better. Lots of water, sand very lightly ACROSS the scratch (never along it, and never circular motions) until it is gone: you are taking clear coat down to the depth of the scratch. Then rubbing compound by hand on the area of the scratch and the swirls. Follow up with polishing compound. Wax layer to finish up. But, as you are getting the whole car prepped for ceramic, never mind!
Welcome to the forum.
