For E30 you should be fine on map3 and can explore map4 on v15+ firmware.
Why is map 5 no longer recommend for e30?
Which firmware are you using?Awesome thank you. I was referring to the old firmware. Looks like I’ll be trying both Map3 and map4 with e30.
Then stick with what terry said. 3 and 4 should be perfectly fine on e30. Just watch your fuel pressure, timing, and afr. If they start changing or you notice the car act funny send your logs in for bms to evaluate
Pull the battery and see if it goes away.
I am also wondering a similar question. Using 94 octane base fuel + BOOSTane mixture that should bring it up to at least 98, I'm wondering if this is enough on its own to use Map3. Don't have access to Ethanol fuel.
Ah, the never-ending debate of Petro-Canada 94 vs Shell 91. I've searched about it prior, the consensus seems to be "Shell V-Power 91 for better mileage, Petro-Canada 94 for better power".Probably - but search for various people from Canada reporting that some 94s are more like 90-91 in behavior, and some other 91s are better..
What’s the best octane to run for JB4 Map3 and Map5? I plan on mixing 5g E85 and 11g 91 (93 is unavailable) which is about E30 and 94 octane. Better to add more E85?
So I'm new to this stuff..... what exactly is e30? Just a mixture of e85 and premium(93)?What’s the best octane to run for JB4 Map3 and Map5? I plan on mixing 5g E85 and 11g 91 (93 is unavailable) which is about E30 and 94 octane. Better to add more E85?
