Electrical engineer here; AWG means “American Wire Gauge”. So as usual, we Americans are the ones who just haaaavvee to be different. Any wiring that comes from another country probably won’t use AWG. Personally, I wish we’d adopt the metric systemI discovered that a "10" on the wire does not mean AWG 10, it means 10 mm2. So close to AWG 8. Everyone should just pick one system and stick with it.
Yep that's what I figured it was. Also found out that the car does not like it when I plug my cheap OBD2 reader in. Random lights start flickeringElectrical engineer here; AWG means “American Wire Gauge”. So as usual, we Americans are the ones who just haaaavvee to be different. Any wiring that comes from another country probably won’t use AWG. Personally, I wish we’d adopt the metric system
Got little over 55 liters of 98 octane into the tank for about 948 SEK.I have less than 20km left on the meter. Will see how many litres i can fill the car with later today.
no idea.So you had 5l left.
I do not run my tank below quarter empty as I've been told any impurities settle to the bottom of the tank and can clog up your injectors.Tank holds 60, and my distance remaining typically goes to 0 at about 4l / 1 US gal.
If only they had something they could put between the fuel tank and the injectors... some kind of filament... that might... filter the fuel.I do not run my tank below quarter empty as I've been told any impurities settle to the bottom of the tank and can clog up your injectors.
....well the wife spent some time at the Shell fuel refinery and that " Knowledge" was imparted to her by someone there. And when I was young I had a Ford Escort and road service attending my broken down car showed me a flake of rust blocking a filter . So I guess that's where it might come from. Any others? I guess filters might just get blocked heaven forbid.lol.. you do realize the fuel pickup is in the lowest part of the tank anyway, so all fuel comes from there, and there are filters both in the tank on the pickup, and along the fuel line?
I'm guessing that advice came from a "knowledgable relative"?
Better safe than sorry, right? Kinda like the OCC's. Plenty of opinions on why to and not to use them. Little bit of insurance that doesn't hurt or cost much. I'm like you, never let any of my vehicles under a quarter tank, for same reasons as you stated but also because then it's not as bad on the wallet to fill up.
I guess you missed the part with the facts just above?
The concern over letting the tank run to empty isnt from clogging up injectors, its from clogging up the fuel filter.
I'm not disagreeing, I am stating that the poster had the subject of the myth wrong. That said, even if you were to ignore the fuel collection location, modern HPFP's, modern fuel and modern (plastic) fuel tanks negate the concern even more.Which part of "fuel is collected from the lowest point in the tank" isn't clear to you?
