So when you have your headlight stalk turned to the first mode (headlight running lights only) the foglights come on too right? And then when you turn the headlight stalk to off everything is off?Just finished mine up. Installed to only come on when the parking lights come on instead of being on all the time. This way, they will only come on when the headlights come on or when the turn signal/hazard lights are on. I also already had the "claws" installed on the vents.
I have heard you can jack up the car and take off the front wheels to access the areas needed instead of taking off the Bumper. That was in one of Vivid Visuals vids he did when installing the DRL's on his Stinger.Really nice write up but of course I'm going to ask. Do I HAVE to remove the front bumper or does that just make it easier? I've only had the car a month so haven't dived into body panel removal yet![]()
Removing the front bumper makes it A LOT easier.I have heard you can jack up the car and take off the front wheels to access the areas needed instead of taking off the Bumper. That was in one of Vivid Visuals vids he did when installing the DRL's on his Stinger.
I'm still thinking about getting them but they are expensive to send here, over $500.This is what I wound up doing. I'm sure it would have been easier with the bumper off, but it really wasn't too bad with it on![]()
So how did you achieve this picture? Because this is how I would want to run them in the daytime along with having the option to turn all lights off.They only come on when the parking lights are on..... so when the headlights are on (either with auto or ON), or when the hazard lights are on.
IIRC, that is with the parking lights turned on on the stalkSo how did you achieve this picture? Because this is how I would want to run them in the daytime along with having the option to turn all lights off.
Oh I gotcha, i guess I’ve been referring to the parking lights as running lights. I’m going to wire it the same way you did then. Thanks!IIRC, that is with the parking lights turned on on the stalk
I was told the white wire is for "half power" to the LED's. You don't need to use it.View attachment 38383 Another quick question, why do the installation pdf and the other discussions have 3 wires coming from the driver/relay but mine has 4 wires? What does this white wire go to?
You should only have to move out of the way the part that faces the bumper, not the whole liner. There is another how to thread that shows how to do it that way.How do you access the wiring through the wheel well? Take off the wheel well cover?
