Stiletto
So, I finally got around to putting the hoopty on the rollers. I wanted to get a baseline, but I was to eager in January and installed the Stillen intakes. In addition to those, I have JB4 on map 2 with 2 step colder plugs. From map 0 to map 2 without the A RK pipes, is a significant gain. After installing the pipes, driving about an hour with several WOT pulls, we put her back on the dyno. The results were less than impressive. However, you can clearly see timing being pulled in the midrange. I do feel the car builds boost faster and pulls a bit harder. Definitely responds faster at highway speeds. The sound is VERY modest above stock.
