ZyroXZ2
- May 26, 2018
Thanks for the detailed write up and follow up video. I've got the Magnaflow on order, and will be mating it with the Jun BL down pipes. I wonder if that combo will be a tad more aggressive. One though I had was doing a 2.5" hole saw cut into the end of the Helmholtz resonator, and welding on a flange for an electric cut out. That might give it a bit more sound. You could use the Varex smartbox controller to program the opening to your liking. It connects to OBD2 port and will open and close based on TPS, RPM and speed. You can also geo-fence it in quiet mode ( ie cold starts at home not to annoy neighbors. check it out: Varex Smart Box
Oh I'm sure there's plenty of ways to rig up something to valve up the exhaust flow, but... I don't really want to fiddle with modes or switches for on-the-fly responses to traffic conditions. Someone in another forum suggested one of the boxes that hooks up to the OBDII and can sense throttle position. That seems the most viable idea, but also serves to drive up the cost substantially while the Magnaflow system wasn't really designed with these things in mind... *shrug* Can't have it all I guess, lol
