Yes I know a couple Stingers that run the Brisk premium LGS “Lamborghini designed” plugs and love them.Brisk Premium LGS Spark PlugSo I read on a forum a guy running the multispark plugs #EOR14LGS
Lol I sense sarcasmYes I know a couple Stingers that run the Brisk premium LGS “Lamborghini designed” plugs and love them.
Brisk Premium LGS Spark Plug They said they have more power, better throttle response and better fuel economy since installing them. They also don’t need indexing or gapping so less chances of issues and easier to use/install. The science behind them(read website link above) sounds amazing and may try them myself too.![]()
Why? Or which part of my post gave you that impression?Lol I sense sarcasm
It’s just a thumbs up emoji and after reading that info page I felt it deserved that positive emotion at least.O ok...just the little smiley face you used
Yeah one has the JB4 running ~20psi, intakes, DPs & catback exhaust. The other has intakes & exhaust.You know if the guys running them using jb4 or any mods?
Those plugs have a heat range of 7, don't require a gappingHappen to know which model/part number they're using? Is it the EOR14LGS? I have so many questions... Gap? Heat range? Electrode material?
And yes that is the correct part #.Those plugs have a heat range of 7, don't require a gapping
All the information you could need and explanations on why this plug is superior to almost every other plug available is right here. http://highperformancesparkplug.com/products/spark-plugs/premium-lgs/ Just take a couple minutes to read it and you will understand why this plug is being highly recommended.Happen to know which model/part number they're using? Is it the EOR14LGS? I have so many questions... Gap? Heat range? Electrode material?
- Yes EOR14LGS is the correct model number.
- They dont need to be indexed/gapped because of the special & patented 4 prong/semi surface firing tips.
- They are the equivalent to NGK's #7 heat range and same as our stock plugs.
They were developed in cooperation with Lamborghini Morori Marini. They have been tested to produce more power, better throttle response & acceleration, as well as lowers exhaust emissions due to the superior combustion in each compression. That's a win, win, win and win to me.
- Electrodes are silver, which is the best thermal and electrical conductor of all metals.
I looked everywhere for something about the longevity....I'll send them an emailIt would be interesting to see back to back Dyno results with the stock plug and these. If they produce a more complete burn or are actually better it should surely show. I'm also curious about the longevity of the plugs.
