Capecod
- Feb 28, 2019
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
That's the virtue of black rims; a Sharpie removes 90% of the visual from a few feet away; and black touchup kits are the easiest thing to find in an auto parts store.Received my new winter wheels last week, while rolling one into the garage my wife came out with our dog..I stopped to pat him and the wheel fell over on its face! couple nice scratches on 2 spokes, here's a picture just before I f'd up.
Was thinking after Snowmageddon last year in Seattle of going the used OEM route (bottom photo w/ Optima 18s) or steel rims and knock-offs ala Lister Jag retro look. Both would be easy to maintain and keep clean in the snow and wet here.
View attachment 30624 View attachment 30625
Good point!When changing to winter set up make sure you keep a set of OEM lug nuts in with your spare.
They may or may not, so you should confirm..it was part of the directions that came with my new winter setup.Good point!Finding out you need them when you have a flat in a snowstorm wouldn't be a happy occasion ...
But are you sure that the tuner lugs commonly used with aftermarket wheels wouldn't work in a pinch? The thread is obviously correct, and the outside dimensions smaller - is the seat angle different?
I see many of you use FC04 from Fast Wheels.Why not their SWITCH model which is direct fit?
I like the looks of the FC04 better (a subjective thing), they are lighter than the Switch model rims (a performance thing), and the design is easier to clean (a convenience thing).I see many of you use FC04 from Fast Wheels.Why not their SWITCH model which is direct fit?
You're doing it wrong, adding spacers will drop your offset pushing your wheels out even more. So for example if you have wheels with an offset of +20 and you add a 15mm spacer, your offset will be +5.K guys, newbie here with a questions that's probably been answered 400 times already. I'm running an 18 GT Limited (GT2) AWD with staggered 19s. Actually using the Fast FC04 in black as my 19" summer rims. Going to 18s for winter so I need to figure out what rims I need. I've read +30 to +40 offset, correct? Now if I found some cheap Core Racing Lizeas in 18x8 that were only +20 would I use spacers to add the other +15 or so? Or am I doing this wrong?
Thanks
Any pics?I went with Fast wheel SWITCH
18x8
5x114.3
67.1
35 offset
Tires P225/45R18
Et voilà!
Any pics?
That’s the exact set up I was about to pull the trigger on!
cant tell really the finishing from the websiteJust put them on today.Just ordered these from Tire Rack for my winter setup, the rep said 40mm would be best for winter.
I think it's a nice change up from the stock 19" summer tires/wheels, black for winter/OEM for summerWhat's with most of the winter wheels on tirerack in black. Some of us don't care for black wheels. Enough with the black wheel trend already. Even winter wheels are not safe from it.
