Matt77
In order to calculate a true DA based off IAT you'd need to also account for the other properties of the air at that point (charge pipe). The elevation doesn't change, but the air pressure and the relative humidity will. The air pressure is obviously much higher thanks to the turbos, but the relative humidity I would think changes as well. Now you have me thinking...hmm. Time to read up on thermodynamics haha
DA is relative to atmospheric conditions, not conditions post compression from the turbo(s).
