Tonkabob
2500 Posts Club!
Good to see its configurable. How do i get a iat wire? Jb4 arrives tomorrow.There isn't that level of precision that IAT signal manipulation, and the JB4 side logic for it isn't setup that way either. We could do more with it but have found the current logic does what we need. Make sure you have the IAT wire installed and enter a "6cyltiming" value to influence IAT. Lower values increase IAT and higher values lower IAT with the change being proportional to the current IAT. Something like a slight colder bias is probably what you need. I'd start at a 60 setting and go from there.
As I said start posting logs and I'll see what we can do to help your tuning. If we see something in the logs that indicates the need for a logic change I'm always game to customize the JB4 code.
I want a hotter bias for cool weather off track dragy days. We don't get full boost until 95 or 100 degrees.
For heat soaked track i think I'm good as is. Maybe try +1 psi by gear / rpm.
