Marc Collins
1000 Posts Club!
I can't wait for that link on where to order one
I am less excited now that I realize (it is there in the Web documentation) you have to fiddle with your phone every time you want to deploy one of the non-stock options. Of course, we can probably expect the Sanbon app to work faster than the KIA UVO one, which is painfully slow and clunky (and quite honestly not worth using except for an emergency I forgot whether I locked the car or the one or two most extreme weather days of the year remote start to pre-cool or pre-heat the car. Otherwise, it's more trouble than its worth.
If some custom setting is just for spirited driving on a favourite road, fine, fiddling with phone is OK. But the real value of this app would be the replacement of the standard Comfort and Sport with something better:
- I am not sure the harder Sport and softer Comfort defaults Sanbon has picked would necessarily be my choices, but that's what we have Custom options for, right?
- No, we should be able to replace the car's Comfort and/or Sport with any of the profiles of our choosing, and have them load permanently until we choose something different with the app (again)
If we select the pre-built "Sport" option, does that change the behaviour of the Sport mode?
And if we pick a Custom mode that we configure ourselves, does that change the Custom drive mode?
Do we get all three at the same time whether we want them or not? Do we only get what we tap on the app screen (one or two or three options)?
I strongly suggest, if it is possible (it probably is not), that the phone app selection (as per the above likely operation) remain programmed until the phone app changes it to something else. Otherwise we are stuck with phone fiddling in a car that has a convenient drive mode dial already built into it. Hopefully, at least, the phone app works to complement the drive mode dial. Not needing to do double duty every time we drive (assuming the even the standard modes are nicer than the stock KIA programming) would make this product much more attractive to the consumer.
