StungBlueGT2
Sustaining Member
I did it while the exhaust was already on the car, but I believe ascidiic suggested dropping the exhaust first to wrap it.So would the best way to install this be wrapping it before installing the exhaust or removing the tips to install it after the exhaust is installed? I wonder how hard it will be to get the ends of the exhaust into the tips with the wrap on during install? I guess the tape is soft and looks like it compresses where it needs to since the tips are an oval shape correct?
It maybe best to pull the tips out, then wrap the ends of the pipes/resonators and finally put the tips & piping into each other so it secures the wrap between the two. May take a little maneuvering of each piece to fit them together properly but in theory that makes sense.
Yes the wrap material is soft so I actually wrapped a separate 2.25” pipe to form the wrap to the width of the backside of the tip(yes oval but slightly more round from the backside). Then I pushed the wrap through the front of the tips until it fit over the pipes. That didn’t seal it completely, so on the other tip I just wrapped it directly on the pipe itself until it completely filled the backside of the tip and then secured it in place. That second attempt filled the tips better and was the best I could figure out while everything was attached.
Either way it works and was well worth the effort. I’m still shocked on how well it eliminates the drone and can’t thank ascidiic enough for the easy fix!
so I replaced the muffler clamp nuts with locking nuts and hopefully won't be hearing the sound of vibrating metal from under the car again.
