StingaGT
my car is making this kind of noise while pushing on gas pedal at "P" gear.
noise occurs while pushing on the gas pedal, not while releasing the gas pedal.
Is this normal?
Is this normal?
CanNOT hear a "squeak". Just a pretty exhaust note. (I am, I should say by this point, damaged in the higher frequency ranges from exposure to gun shot - applied solid core ear plugs incorrectly on a singular occasion and haven't been the same since. Maybe my Stinger is "singing" to me in ultra high soprano tones and I am oblivious!Can hear it in this video of mine
I hear it. Sounds like the squeak of a hinge.Can you guys not hear the high frequency metallic noise just before rpm needle moves up?
Is it your throttle body opening? Sounds almost like an unlubricated hinge. Any modifications to the car?
He's talking about the squeak mine does this I was told it's normal. Can hear it in this video of mine
my car is 100% stock
I can't hear mine inside the car definitely related to the throttle though that's when I hear it.Huh, I'll have to check my car (Stock GT2 AWD) and see if it also makes this sound.
Depending on what it actually is, most likely it’ll just be an annoyance. My 30k mike Suburban throttle body squeaks, very very common with POS Chevys. I just have to listen to it squeak. People have taken their cars in and the squeak returns eventually. Since you have a warranty, no issue with at least getting it checked. Actually, if I were you...I would get it checked to be safe.Can I let it squeak or will it cause more problem in the future?
